Re: 71 Johnson 6 hp replacing starter pull cord
Courtesy of Joe Reeves, a frequent poster who I haven't heard from for awhile (????)
(Manual Starter Cord Installation)
(This pertains to the vertical type of Manual Starters such as the 9.5hp and later 6/8hp models etc)
(J. Reeves)
1 - Have a pair of vice grips handy set so that they will grab the top of the starter spindle tightly but will not damage it.
2 - Using a large screwdriver inserted into the top of the starter spindle, wind the starter in a counter clockwise direction 12 to 14 turns, stopping so that the cord locking slot is facing the away from the engine.
3 - Lock the spindle in that position with the vice grips, letting the vice grips lay against the flywheel.
4 - Insert the cord as needed and make sure it is retained properly at that slot.
5 - Feed the cord out the starter cord hole at the front of the engine and attach the handle.
6 - Grip the cord tightly so that the spindle cannot spin around rapidly, then release the vice grips.
7 - Allow the cord to be withdrawn slowly around the spindle.
