bamafan1550
- Nov 22, 2009
- 2
Ok got a 89 omc 150hp I know the trim/tilt motor is bad (no power on the direct connect). I need to get it out. I have the motor up on the motor locks thanks to the purge screw. I have 2 screws out but cant get to the rear left (against the transom plate). It appears that the entire trim tilt will come out without pulling the motor but I cant tell for sure. If it will how do I go about it / or is there an easier way?
