Re: No warm up lever?
Hey guys...I just came across this discussion, as I too have a fast idle/ warmup lever issue.
I just winterized my 1996 Johnson 115 yesterday, and as I was running the motor with the stabilized fuel, I noted that the center push button at the bottom of the throttle did nothing, i.e.: did not affect the idle. Could this mechanism have been dismantled? cable issues? ...or perhaps as you have al stated, there is another mechanism that controls the fast idle.
By the way, I have received a tremendous amount of help/ info from many of you, which is very much appreciated. You have all been "right on" with your info. I just saved almost $300 from the 'winterizing' advice I received from you, and did the job myself which was surprisingly easy. Being a new boat owner, I am somewhat addicted to this site, and can't wait for spring! Thanks again!
