On my motor there is a manual choke lever, (on/off/automatic) located on the motor by the carb, automatic choke (temperature controlled I believe) and electric choke (solenoid).
When in auto position is that for the automatic choke only or does the choke lever have to be in auto for the electric choke to work as well?
Do the automatic choke and electric choke operate totally independent of one another or are they somehow linked?
Automatic choke: When rebuilding the carburetor, I removed the automatic choke and I don't know if I put it back together correctly or if the spring tension inside the cover is what it should be so this may or may not be working. I saw the markings on the cover and tried to realign them as they were but the spring tension concerns me. How can I tell if this is working.
Electric choke: Don't know if this is working. There is a very short toggle switch on the control panel that toggles up and down. Should I be able to see the choke plate close or hear a noise when toggling this switch?
Thanks,
Ron
Thanks,
Ron
