I'm having a re-occuring problem with the tilt/trim unit on a 2004 115hp 4 stroke. This Johnson outboard (JPL 115) is a Suzuki DF 115 marketed by Johnson in the 2003. The tilt/trim motor leaks oil out and ultimately lets water in ruining it. The unit has been repaired twice (under warranty) and now it's leaking again for a 3rd time. The dealer will fix it for $ but I think Johnson (Bombardier) and Suzuki should look at this for me and make good. This engine only has 180 hours on it. Has any one had a simalar problem?
