I have a 1993 johnson 88spl on a 16' aluminum runabout. I put on a new throttle cable a couple of months ago and haven't been able to set it properly. I've only had the boat for for about 8months so I'm not sure if it's always been like this or if it's a new problem. When I adjust the new cable with the thumb wheel so the throttle cam returns to the idle stop I can't get anywhere near the WOT stop when I push the throttle lever up front to full throttle. When I adjust the cable to get more throttle it won't return to the idle stop. It's like there's not enough stroke in the cable. I've sent hours trying to figure this out. I've even taken apart the control box to make sure there were no worn out bushings or broken pieces. Does anyone have any ideas?
