Guys, I'm trying to remove the tilt unit from my 2000 Johnson 50. Could someone take a look at the last pic at the link below and tell me if I am correct in that I just need to remove the two nuts on the bottom pin, apply some Liquid Wrench, let it soak in and then hit the bolt with a hammer until I can get it loose? And on the top pin, how do I get it out? On the starboard side the end of the pin is tucked back up in there. I have drawn red arrows pointing to the bolts/pins in question.
http://picasaweb.google.com/willfisher929/JohnsonTilt#
Thanks
Thanks
