Postmarc
- Nov 8, 2009
- 7
Fairly new to iboats, but used a lot of previous post info during my project--thanks to all who share good tips.
I just finished restoring my first boat, a '57 runabout. Took it out recently and the Boat Gods are punishing me by not letting all the 40 horses run.
Motor was gone over by a mechanic after sitting for 5 years (fogged), impeller and plugs replaced, all fluids replaced. First time I took it out this fall, full power was not an issue. 3rd time, I can only get up to about 1/3 of what I could before and doesn't get up on plane. Purrs like a kitten, runs smooth, just slow. I have switched pressure tanks, switched fuel bulb lines, switched gas, and checked the throttle linkage to make sure the set screw didn't slip, all to no avail. I shot carb cleaner in while my daughter drove. Nothing. Any suggestions?
