Hi to all,
Lost my 48 spl to katrina, replaced it with 1981 johnson 70 hp. In 2007. Spent the last few years rebuilding my home in St. Bernard and finally finnished. Well a few months ago started rebuilding my trailer and finally took the boat out.
When I replace the engine I replaced the water pump impella and s/s houseing and the thermostat and some other grommets in the stat area. When I originally replaced the stat I tested and had strong pee stream but when I ran the boat fast the stream would stop. But after stopping the engine and restarting it would start again.
I went out yesterday and same thing. Strong pee stream and it would stop after running fast. But after a few times it stopped altogether and only had a low stream when restarting engine. I fished and let it cool. I trolled back to the launch. Restarted at launch to put boat on trailer, very weak pee stream.
Any info would be appreciated.
Sincerly,
David
Sincerly,
David
