mettyfish
- Jul 3, 2007
- 180
There is not the normal 4 bolts under the cavatation plate. But I see 2 close together under there and one on top near the shift linkage. Which ones do I take out to drop the lower unit for impeller change. What else shall I look for while trying to get this started. I know I will probably have to clean the carb. Does this motor have a telltale? Thanks, Metty
