My 1990 25 hp Evinrude will run fine at high speed, and then suddenly while on plane lose all power and revert to idle speed (i.e. as if fuel only going thru low speed jet). Then after shifting several times from neutral to forward, it will again run fine for several more minutes until the same thing happens. I have cleaned fuel filter, changed fuel tank and fuel line/bulb....no help. Could it be a piece of crud which is periodically clogging the high speed jet? If so, is there an easy way to clean it out? Thanks for any advice you can give.
