Im new to the outboard thing, I just ran my 72 50hp evinrude. I had to pull apart the lower unit because it wasn't shifting. I adjusted the soliniod rods an got it to shift. So I had it on the water I was unable to get it to stay running in low idle so I had to shift at high rpm. It ran great, expecpt the high rpm shifting. got home an drained lower unit found metal shavings an the oil was milkly. Any knowledge on the issue would be great.. I fear that I f-ed somthing up all the gears looked great it was the first time I ran it.....
Shad
Shad
