I posted a thread a couple of days ago stating I couldn't get my motor to start. Well I figured out the problem. I needed new fuel lines. I went to walmart and bought a new fuel line and it started! The motor ran for about 45sec and died. I took it down to the lake to mess around some more...
With the fuel line connected to the gas tank, and the screw loose on the cap, it wouldn't start. So it thought it was flooded. I took the fuel line off and after 3 or 4 cranks, it started and ran with the choke held down. When I reconnected the line to the tank, it died?!? Yes the screw was loose. So I disconnected it again, and it started. Then I took the whold cap off and reconnected it, and it still died! Also, there is a red switch on the side of the motor that has something to do with it, but I'm not sure what position it is supposed to be in. Finally, there was one time I had the fuel line connected and it ran. I put it in gear and hulled half way down the lake, and it was running great, and then it died. So...
Does anyone know why it would be dying (Gas is new 93 octane and separate oil reservoir.)?
What is the red switch, and what position should it be in?
The motor is a 1992 Johnson 60hp and the guy said he had the carbs redone in 08. Thank you for your help!
