Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
OMC 70 TSB 2276 - that never happens!
  • OMC 70 TSB 2276 - that never happens!
    So yesterday I went to apply TSB 2276R1 to my 1989 Johnson 70, as detailed here: http://forums.iboats.com/showthread.php?t=222677. I have a very occasional overheat problem, so wanted to bring the motor up to date with all the TSBs.
    I got my 1/8 NPT tap and drill and was ready to go. It didn't look like a tough job, but drilling into an engine block is something I'm never going to be comfortable doing. So I scoped out the location for the telltale nipple. Hmm, a bolt right near there. I removed it - not a bolt, but a pipe plug with a hex head, never seen that before. Turns out the replacement powerhead put on by the previous owner must have been a later block, with the hole already drilled, so all I had to do was swap the telltale nipple and the pipe plug. And the money spent on the tap wasn't a waste, as I needed to chase the threads to reinstall the nipple.
    And then I slapped on the muffs and started 'er up - no leaks. I'm going to play the lottery this week.
    Tim
    Re: OMC 70 TSB 2276 - that never happens!
    Love to hear that good news. If you win the lottery let us hear that good news too.
    All of my vehicles are "works in progress". I choose to buy things I think I can repair. Not until I put work into something does it become mine. I hate selling "my" things. I would rather give them away.
    • #3
      If your doing updates go ahead and change impeller, on certain models of 60/65/70's from 1986-2001 Johnrude's had a 3 vane impeller(437059) which was a high volume impeller but it had a lower pressure and is NLA due to problems in cooling(part of TSB 2276 problems by not filling block up). Replace it with the 6 vane 396725 impeller.
      When in doubt,Trim it out!!!
      Business Owner & Certifed Technician
      Boats I own & use
      20ft Javlin w/250 Junkrude
      17ft Bullet w/200 Merc (SOLD!!)
      13ft Allison w/150 I-6
      17ft Hydra-Sport 175GT
      15ft Allison w/75 Stinger(project)
      14 x 48 Drifter with 1100SS Merc
      • #4
        Thanks FB! I was not aware of the impeller change, but I did replace the water pump a few weeks ago - both the old and new impellers had 6 vanes.
        Tim
