Background-On my way back from a fishing spot I was running wot when the engine began to miss, skip. Limped back in (30 minutes) took the boat home and started to work on the problem. The skip was not preceed by any mechanical noise. Boat was running fine all summer. I have a water seperating fuel filter and a battery kill switch an internal tank and the boat is primarily used in salt water.
I have a 2000 90hp Johnson that has a miss, skip. At high speeds above 2000 rpm it's more significant. When it skips there's a ping,knock coming from crankshaft area. Been playing around with this engine for a month now let me give you a list of things I've tried. Compression about 125# all 4 cylinders.
Isolated fuel system with seperate tank and fresh gas---no change
Changed coils, plug wires, stator, powerpack---no change
broke engine down changed crank shaft bearings---no change
changed piston rod to crankshaft bearings also--No change
Rebuilt carbs changed all fuel gaskets checked reed valves----No change
Removed and resealed heads----No change
Cleaned out the exhaust while engine was apart
Move battery from under center console to back of boat---No change
Isolated kill circuit--No change
Disconnected voltage regulator-- no change
Removed each plug wire one at a time to see which cyclinder was the culprit no change in performance still skiped and missed cannot isolate 1 particular cyclinder as the problem.( I used a grounded old plug so I wouldn't damage the electrical system)
Findings --some wear on crankshaft especially upper bearings but didn't mic them. I couldn't feel a ridge with fingers/fingernail just discoloration. Piston rods had some flaking taking place near the crankshaft end but didn't seem to bad. Some evidence of water leaking from top of head down cylinders. Thermostat inner seal was deteriorated. When I had the engine apart I checked the reed valves none broken or bent open all seemed to open and close easily.
So far I've got about $1600 into it with no results does anyone have any idea what could cause this. I was pertty thorough and careful but I'm totally stumped there's nothing left to change and the engine still runs like crap.
