85stratosman
- Oct 8, 2009
- 14
Well after running into alot of problems on my 1987 Johnson GT 150 and discovering it would run around 3 grand to have rebuilt, I found a 1979 Model Johnson Seahorse 150. The motor's compression is good with 113 psi being the lowest and 120psi on three cylinders being the highest. The lower unit had good clean lube in it and the trim works good and doesnt leak down. It is going to need the carbs cleaned and new needles and seats, but all in all I guess what I am wanting to know is would this motor run pretty good for its age as far as pushing an 18 ft stratos bass boat and is it worth 400.00?
