I have a 1999 200 ficht. It has set the code #16 61 times. The power head seems to cut out at about 3000rpm but doesn't always do it. It seems to be getting worse. I have ohmed the crank sensor and it read 1080 at room temp.and the air gap is within spec. Does anybody have any idea on why it is losing engine syncronization at mid range rpm. Thanks for your insight!
