Re: How many pole is my motor?
Ok, its all hooked up correctly. There is no setting for 6 pulse? But settings for the correct amount of poles, its at 12 pole. Now it didn't work, but I noticed when under the dash that the c clamp that holds the gauge in the dash, it bolts down on two studs one stud being the B+ and the other being light B+, and the ground stud goes through a hole in the clamp, and noticed that it was touching the clamp, that cant be good, since that clamp also touches the B+ terminal, so I drilled the hole bigger, and now the tach works. Its slow to respond and sticks high sometimes, but maybe its just sticky from not being used in years, maybe it'll free up!
