johnson 2HP
petec
Hi everyone
I have just aquired a Johnson 2hp outboard, model J2RCNE ser No. B026075.
The label says made in Belgium. I would like to know a bit about it if possible. How old is it and what sort of mix should I use. Thanks a lot.
Petec
Vic.S
Re: johnson 2HP
CN are the date letters for 1982
It will run on a 50:1 fuel mix
The plug should be RJ6C gapped at 0.030"
It has a points ignition system (0.020")
Separate idle and high speed adjustments on carb (See the Engine FAQs board for Joe Reeves' instructions on adjusting)
Most parts seem to be available.
