Re: 1972 Evinrude 25HP - Very hard to pull
Spark it the next thing to look at.Be Sure you have a good spark across the plug gap.Heres what I have run into.Mine has a single coil to fire both cylinders.The coil at shop evinrude shows the same one for the double coil system. my coil has two wires, going to each set of points.Maybe the drawing is wrong,but I haven't checked the part # yet.Im still working on mine also.Good luck
