The tachometer on my 90 e-tech has stopped working.
The engine starting lamp sequence is working so assume volts getting to guage. Have checked connection on back of tachometer and they seem tight and ok. Where should I look next? Does the tacho get its signal from the engine management electronics block? If so does it mean a replacement of this item, it looks expensive, can you get a service/exchange.
Where do I go next??
Any advice gratefully received.
Paul.
Paul.
