Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Adding a rigging tube to an older Johnson.
  • Adding a rigging tube to an older Johnson.
    Has anybody added a rigging tub to an older Johnson outboard?
    I love the clean look a rigging tub addes but I have not seen them on the older Johnsons.
    Re: Adding a rigging tube to an older Johnson.
    Mercury makes a good rigging tube ... I used them for my new E-Tec's 3 years ago. The end connectors need to be sealed in place with 3M 5200, or the ends will pop off the tubes. I'm sure there are other good rigging tubes as well available.
    Jim
    I don't respond to Private Messages PM's that are motor questions.
    For basic information on a wide range of topics, see Top Secret File
    Link: http://forums.iboats.com/showthread.php?t=299680
    OEM shop manual: outboardbooks.com or Ebay
    • #3
      I have thought about using old vacuum cleaner flex hose. Cheap and easy to use. any thoughts?
