Wohoo first post. Down to business now...
First off, I have some car motor knowledge but it's all EFI not carb and not marine.
Got a boat with a V4 1961 75hp Evinrude Starflite III. Unknown when the last time it was used but tags on the trailer point to 1991 After a lot of frustration got the motor to turn over (missing key). Then we got spark. Then we were having a hard time getting the motor to start. It finally started but any bit of throttle (by hand at the carb) kills the motor. We figured fuel starvation? We checked the fuel pump and it seems to pump well.
MAIN QUESTION:
Am I heading in the right direction to rebuild and clean the carb next?
Compression even all around at 90psi +/-1psi.
MAIN QUESTION:
