Lower unit interchange chart
Status
Not open for further replies.
Faztbullet
I have seen quite a number of posts asking for this so here goes:
.....(This chart for direct bolt on with no part changes)............
Horsepower--------------------------------------Years that interchange
40/48/50/55/60..... (small diameter housing)..................1976-1988
40/48/50.................................................................1989-1992
40/48/50.................................................................1993-2005
70/75............................(20 inch shaft)......................1978-late 1981
60/65/70/75.............................................................1982-1988
50/60/70..................................................................1989-2001
85-140.............(crossflow 13 spline prop shaft).............1978-1991
88-140.............(crossflow 13 spline prop shaft)..............1992-1998
120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
150-235 & 2.6.................(crossflow V-6)......................1979-1991
185-225.........................(Looper V-6).........................1986-1991
185-225....................(Looper V-6 & Ficht)....................1991-2005
150-250.......................( Magnum Series).....................2002-2007
150-250........................(Lighting Series)......................1997-2001
I will add more as I get information !!!:D
tashasdaddy
Re: Lower unit interchange chart
great info, i added it to the TOP SECRET FILE.
bob johnson
didnt see the 1995-? V4 looper with 13 spline( yeah what I have !!)
small gear case... which makes it hard to find lots of prop choices....
the 15 spline large gear case has a ton of props available
( oops I see the "add more later" comment...sorry
thanks for the list , i just used it to verify a used parts motor purchase ill make
bob
Northwoods
Pardon the lack of boat knowledge, but is this chart for every make of boat motor? The reason I ask is because I am currently searching for a used lower gear case for a 1989 50HP Johnson model #J50TLCEC and am having a hard time being able to tell what exactly will work on my boat. I found one that said it would fit any Johnson between the years of 1975-2006 but according to this chart that would not be the case. Correct? Thanks.
1946Zephyr
Evinrudes won't work on Johnson.......till you change the paint color.:D:D:D
bob johnson
no way that all 50 hp outboard wether johnson or evinrude or both will have interchangable lower units from 1976 to 2006!!!!!!!!!!!!!!!!!!!
I know that 1989 was a year they changed lower units....follow the chart here.
bob
Faztbullet
You need the 1989-92 year unit. Do yoiu need a complete unit or just the housing?
bob johnson
here are the choices for you the way i read that site..
http://www.sterndrive.info/outboardmotor/small_loop_charged_1975_1988.html
or this one
http://www.sterndrive.info/outboardmotor/small_loop_charged_1989_2005.html
but since you say you have a 1989 model the second link is for your motor...
I dont know what constitutes a large gear case for the 2 cylinder model outboards
maybe there were some commercial units...
good luck
bob
bob
blimp
bob johnson
James R
Bob J. That would be a most useful site. Maybe someone out there has it.
hardsoko
I am currently looking for a lower unit to fit a 1982 60hp 14spline 20" shaft. After looking at your chart it looks like i have several year options. my question is how do i know if its a small diamiter housing or not?
I have small metal shavings in my lower unit oil. its not creamy though. I guess I am looking for a lower unit aswell (tear) But I am not looking to pay out the ***. I build import car motors all day But when it comes to an outboard I can make out what I am looking at but it is all diffrent.
I have a 1983 or 82 johnson 140 v4 seahorse. The lower case gears must have screwed up. I cannot get the lower unit drain plug out. So I put some vaccum line on my gear oil and shoved it down in the lower part of the gear case and was letting it over flow out (not correct but kinda works) and I seen metal shaveings and what not.
So I cant understand what lower unit to buy. I read something like 85hp-140hp? are interchangeable. But what is all this about drive shaft length and shifter length.
If someone could tell me the years or hp or size lowerunit i wold be veary greatful. I hope someone can help me understand all this.
bob johnson
. ....... So I put some vaccum line on my gear oil and shoved it down in the lower part of the gear case and was letting it over flow out (not correct but kinda works)...............
well this part of your post has me totally baffled.....
not that it is important, but you might want to re phrase that..
any way this line on the chart is what you need to remember...
so that seems like:
85 hp
88 hp
90 hp
100 hp
110 hp
112 hp
115hp
120hp
130hp
140 hp
if it is one of those CROSSFLOW hps and it has 13 splines on the prop shaft and it is in between 1978 and 1991
you should be ok
good luck
bob
Thanks bob.
I slowly weved it down into the lower case.
Ok thank you for helping me. I know this site probley has the same quistions over and over like most sites. At least this one they dont bash you as hard.
hey is this true as well if you KNOW your motor is all OMC-OEM.
"IF the motor has two 2-barrel carbs made of aluminum positioned one above the other, it is a cross-flow from the late 70's.
If there are 4 individual plastic carbs, you have a "looper" from the mid 80's on up"
I have been digging trying to find this out. Is this true? I pulled a plug and looked at the piston just to be sure and what you say is accrate. And I do have 4 carbs. So is that guy right to? seems alot easyer to pop the cover off the motor and look at the carbs then pulling a spark plug.
Let me know if you think that is right aswell.
thanks iboats
ezeke
If it has two 2 barrel carbs on a V4, it's a crossflow from the 1960's through the 1990's.
There were no 140 crossflows after 1984; that's when the V4 loopers come in.
The early V4 Loopers had 15 spline propshafts on the extra long gearcases but had 13 spline propshafts on the others. That's clearly shown in the parts catalogs which have different diagrams and parts lists for the different drives.
Status
