Hi all...I am posting this new thread because I guess I highjacked another with a similar problem to mine. I apologize to all for that improper use of forum. Live and learn EH?
My 1997 15 HP 4 stroke evinrude has a carburetor with an accelerator pump that has a casting on the bottom with two nipples so the tell tale can connect to each side. Water goes in one side and out the other. I have been having problems with water stream weakening at idle and intend to tear the engine down this winter and clean it all out. I want to know if this accelerator pump (part number 27 in attachment is where tell tale hoses attach) can cause a weak stream for any reason. Why is water running through there in the first place?
