This motor has the two line fuel system. The gear case was full of water and the bearing or seal on the back on prop shaft is beat up.
Do I turn it upside down and take the bottom cap off? Will anything fly out? How does that seal/bearing go in? Will a 1/2" socket go over the prop shaft or would it take a 3/4"? Thanks.
