This applies to a 20 hp 85 Evinrude, model number CE20CRCOS
The lower unit on the engine will not drop. I have proceeded according to the Seloc guide, first disconnecting the shift rod connector behind the inlet screens and then removing two bolts on either side and the nut at the front of the lower unit. There was no visible corrosion on any and they all came off normally (the motor is generally in good shape from that perspective).
The problem is it remains tight at the front. It will wiggle from the back and I can get a crack of about 1/8 of an inch at the back, but not budging at the front. I have been using penetrating oil and pressure, but no luck.
Is there anything else that needs to be undone? Any other suggestions? Can I wedge between the housings?
The objective is to work on the water pump as the engine overheated.
