Anywhere from 2/3 to full up position, when i tilt down, the tilt motor runs but it has this dead spot starting at full up where it just makes its RRRRRRRR noise, then it catches after about 10 seconds and continues down like nothing happened. During that dead space the motor is free, and if you let up on the button and walk back there you can push it back and it drops to the lowest position it can for the time youve held the button.
As it runs (with no motor movement), it apparently thinks its got the motor down as the little pistons for the fine tuning will start to retract while the motor is still sitting up high before it catches and starts going down. Once it gets to dead bottom and i push it back up a bit again everything evens out and the precision ones work properly, provided i dont bring the motor up high enough to get into that dead space.
When its near the bottom in a normal running position while im out it has no problems, its only really an issue when first launching and getting the motor down to start it. Those bottom 2/3 are just great once its in them.
I had a boat mechanic look it and it and he just refilled the tt fluids and ran it a while and said if it goes down eventually dont worry about it and that a replacement piston would run me more than the motor is worth. That seems a bit extreme to me.
Any suggestions on rebuild kits for the thing, or other fixes greatly appreciated.
