I have a 1989 60 VRO. I have all of the bolts removed needed to lift powerhead up and the powerhead will lift up and move alittle left and right. I don't understand how to dis-engage the shift linkage rod ..... the manual says to pull the shift rod clip & push rod into the powerhead ..... I do this but it doesn't seem to release anything ... I do not want to lift the powerhead up until I know I have this released correctly .... I don't see any bolts or clips that I can remove up under the carb area .... any help would be great !!!!! Thanks ... Doc
