freetime99
- Sep 11, 2007
- 129
Have replaced: fuel line & primer bulb, on-motor fuel filter(is no other),all connections to tank verified as tight.Cleaned both fuel tanks. The motor will idle well but when you put the gass down, after getting on plane, it will sputter, will run fine if you continue to squeeze primer bulb. Engine runs very smooth when getting fuel. It acts as if it's fuel starved. Is this a failing fuel-VRO pump ?? If so, where can I get a non-VRO, simple fuel pump? Local dealer says Bombardier no longer lists a conversion/simple fuel pump for the engine ( 1999 Johnson PLEEB- 60 hp 3cyl.). Does this sound like failing VRO pump ?? ( engine has very few hours on it but has been in use 8 yrs, capped off oil side when I bought it new)
