need help i just bought 1991 intruder v6 stalling out i had new thermastats put in and new water pump .when i put it in gear it will move backwards about 30 feet then stall .foward it stalls has soon has you put it in gear.. starts right back up every time ..idels fine.. baby it in gear and it will take off topend speed great i can idel around when i get pass that hump of dying . did compression on all six . i had 95 to 91 compression all cyclenders called dealer they said that was about right for this engine and i was using to long of line to compression gauge only one i have . they said its fuel related maybe bad gas i drained the tanks fresh fuel . and cleaned carbs. i did notice on all carbs the idel screws are turned all the way inn . when it starts to die i get a sneeze out of carb thanks for any help
