AEROCOOK
Master Chief Petty Officer
- Jul 28, 2004
- 872
My 1988 110 Johnson runs great at one quarter throttle and above but when cruising at very low speed or taking off after it has been run at slow speed it has an annoying mismire.
I have checked the timing,, done a link and sync and cleaned the carbs but the problem persists.
Today while cruising the river with my 12 year old son at the helm The misfire began so I instructed him to maintain the current speed (still misfiring) for a few minutes then I reached over and turned the key off and pulled the plugs out to see if I could identify the affected cylinder.
What I found was that the 2 port side plugs were wet, black and oily while the 2 starbord side plugs were the desired brown / tan colour.
I also found that the port side head was noticeably hotter than the starboard side but I could still hold my fingers on it for 3 to 5 seconds and no alarm sounded so it wasnt over heated. Next I put the plugs back in, took it for a 5 minute cruise at 4500 RPM and repeated the plug check procedure, this time the head temperatures were even and the port plugs were brown and dry.
I dont know if the misfire and the cooling thing are related so that is my first question. My second question is simply what could be the cause of this (or these) problems?
