I need the torque spec's for the flywheel nut on my 1978 johnson. Thanks Dennis
D Dennis Evans Recruit Joined Nov 22, 2004 Messages 4 Aug 22, 2009 #1 I need the torque spec's for the flywheel nut on my 1978 johnson. Thanks Dennis
bktheking Vice Admiral Joined Jul 29, 2008 Messages 5,057 Aug 22, 2009 #2 Re: Flywheel nut torque on 1978 70hp johnson 100-105 ft lbs
D Dennis Evans Recruit Joined Nov 22, 2004 Messages 4 Aug 22, 2009 #3 Re: Flywheel nut torque on 1978 70hp johnson Thanks I was thinking that it was more then that becuse the nut was 1 5/16 so 105 it will be. thanks again Dennis
M mike carson Cadet Joined Aug 13, 2012 Messages 14 Sep 1, 2012 #4 Re: Flywheel nut torque on 1978 70hp johnson Would it be the same for 1987 40 Johnson?
