I have a real descent 115 electric shift motor. Until the other day absolutely no problems. the boat is in near showroom condition. Started everytime with just a tap of the key. good compression at 125lb.per cylinder. I was having issues with starting and so i replaced the plugs. it started but was running a little ruff. I cruised it for a couple hours and then took it home. I tried to start it the other day and nothing. I am getting fuel, plugs are wet. I have spark, bright blue. I looked a little further with wire conections and any other issues and only found that the flywheel woodruff key was worn. thought for sure i found the problem. Nope!. I took the flywheel off again and looked into the magneto and the pickup. dont see anything out of the norm. i still cant get it to run with only a cough when i try the starter for a few seconds and occasionally get a sputter when i am just letting off the starter to kill the the ignition.
I am lost. I think it is timing but dont know how to adjust that. The advance looks to be stationary. the sticker on the cap on the 'distrbutor' if you will, calls for the "sensor gap to be .028 inches" where do you adjust that?
the only problem I have had with this motor is occasionally the electric shift gets caught between gears. any ideas that this may have something to do with it?
The nuetral safety switch is working as well as the electric choke.
Need help. dont understand why all the sudden this beauty isnt running. please help.
