Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How to torque the flywheel bolt...without a torque wrench?
  • How to torque the flywheel bolt...without a torque wrench?
    Finished up a 5 HP Johnson today. All I need to do now is tighten up the flywheel bolt. I got it off using the hammer hitting the socket wrench handle method that I read about some guys use....worked fine.
    Now I need to put the flywheel nut back on..so can I use the same method to tighten it back??
    I only have a 150lb torque wrench...the manual says I need more than twice that!!! I also don't have a strap wrench.
    What do you guys do? Many thanks for the advice.
    Re: How to torque the flywheel bolt...without a torque wrench?
    There's NO WAY the specs call for 300+ foot pounds torque on a 5hp motor. You'd better go back and read the manual ... more likely the specs are in INCH POUNDS!
    1996 Evinrude 9.9 4-stroke
    1995 Yamaha 115 2-stroke
    • #3
      Double check the torque !!!
      sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
      • #4
        Yepper!
        It would be fun to watch someone trying to torque a motor to 300 foot-pounds. I'm visualizing a 6 foot cheater pipe and a strap wrench from Hades.
        Sorry,
        Couldn't resist......good luck. The inch-pounds thing threw me a loop once upon a time as well!
        Good luck,
        JBJ
        Not a certified mechanic but I have at least 2 shade trees in my yard and my wife always says I'm certifiable. So remember that when you follow my advice
        • #5
          INCH POUNDS....I must have mistaken for FT. Pounds!!! I will recheck the manual tomorrow. Duh!
          • #6
            Try 40 ft. lbs. That will do it just fine. Asking how to torque without a torque wrench is like asking how do you drive 35mph. without a speedometer. You can't. Best of luck. Rick.
            • #7
              Although many wont like this answer as it wont give you an accurate torque/lbs... I used a air gun to take it off and put it on. It works just fine and i had no problems related to doing this. Im not saying its the right way, but it will get it off without damage and it seems to get it on tight enough.
              • #8
                Yepper, doing that makes all sorts of people $$$ or adds to the landfills with ruined components...
                1973 Glasply 21' Camper Cutty --- AKA Mean Green
                Originally Mercuiser 888
                Rebuilt FWC SBF
                SEI 106 Upper and Lower
                • #9
                  That is a great way to get it off, but a terrible way to put it back on. That is a great way to spread the flywheel hub. resulting in a ruined flywheel and a broken points cam when the spread flywheel goes down against it. It happens all the time. Then people wonder why their cam breaks.
                  There is a reason for the narrow 5 ft/lbs tolerance allowed in the torque.
                  • #10
                    The torque is 40-45 ft/lbs. I set them at 43.
                    Wayne
                    • #11
                      Well if you go crazy and force it on beyond a reasonable amount. It worked fine for me but i made sure to only use about 80 psi to the air tool and stop as SOON as theres resistance. However, it is a bad way if you want exactly between 40 and 45 lbs
                      • #12
                        I have calibrated my right arm for torquing.......just took years of practice....just kiddin
                        • #13
                          Here is a easy to use converter for torque. http://www.pitt.edu/~rsup/touqueconv.html
                          • #14
                            I use the air tools on my volvo crank pulley but its steel ( or iron) done it a bunch of times , never a problem.
                            But flywheels are alum and will distort.
                            It happens all the time with alum wheel rims when they use the impact wrench.
                            sigpic
                            See FAQ Files.
                            http://forums.iboats.com/showthread.php?t=299680
                            Get the genuine factory service manual.
                            www.outboardbooks.com
                            • #15
                              Use torque wrenches. That is the only proper way to be a mechanic. (even a shade tree variety)
                              Bolts and nuts stretch every time they are torqued and stay stretched. That is why many manufactures suggest to replace bolts and nuts so they eventually won't break. Why take chances of being stranded because of fatigued (failed) bolts or nuts.
