I have a 15 hp Evinrude 4 stroke that is not wanting to start up. I have used it once this year with no problems at all. It has always been a one or two pull start for me, but now won't turn over. I took apart the gas line that seats between the spark plugs on the motor and the gas came through the fuel pump to that point no problem. I then took the plug out and touched it to the side of the block while I pulled it over and had spark. After squeezing the primer bulb a few times and pulling it over once, I pulled the plugs and found they were dry.
I'm a newbie and really am not sure where to go from here.
Any advice would be greatly appreciated as it seems impossible to find a cutaway diagram for my motor online.
Thanks,
Jamie
Thanks,
Jamie
