Grantman420
- Feb 5, 2008
- 5
I recently bought a used 70 hp Evinrude Triumph for my 15 foot open bow fishing boat project. It runs good on the muffs but I'm not sure of the condition of the impeller since there is no tell tale. I decided to purchase a complete impeller kit and do it myself. It looked pretty straight forward going in but now I'm stuck. I removed all of the bolts on the lower unit and removed the trim tab and marked where it was. I put the gear shift in reverse and got the lower unit to drop but only about an inch then it gets stuck on something. I removed the cotter pin at the shift arm and pulled it out toward the starboard side (slicing my finger on the motor in the process. After 4 stiches and some cuss words it still does not want to drop. Has anyone else run into this or have an idea of what it is hung up on? Any advice would be greatly appreciated at this point.
