Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1968 Johnson 65 hp VXL 14B
  • 1968 Johnson 65 hp VXL 14B
    I need a pinion bearing for the subject engine.
    Heavy duty Gearcase group bearing is 0377133 BEARING, Pinion, lower $41.00
    The Standard Gearcase group bearing is 0378264 PINION BEARIN $102.00
    How can I tell which one I need?
    bob
    Re: 1968 Johnson 65 hp VXL 14B
    The heavy duty gearcase looks like two halves bolted together, the standard duty gearcase is all one piece.
    '90 Chaparral 2000SL
    5.8 Cobra
    '67 MFG Westfield Regal
    80hp V-4
    (No private messages)
