Johnson 50hp 1982?:
I have changed the impellor in my outboard. Now it is "only to put the parts together"...
The problems i encounter is that i do not know how the long "gear shift rod" shall be rotated. It has a little bend in the upper end. Shall the bend point forward or backward?
Also, it seems like i have some problems with aligning all the parts. "Gear shift rod" upper end to fit in to its "clamp". Drive shaft. Exhaust. And there is another pipe coming from upper engine part down to next to the impellor house.
Any tips and trix for how to make it easier to assemble the parts again?
best regards from Sweden.
Matza
Matza
