Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
33 hp Johnson...year and oil mix?
  • 33 hp Johnson...year and oil mix?
    I have an electric start 33 hp Johnson that came with the boat I just bought. The model number is RXEL-16R and if I figured it out correctly, it should be a 1968. Could someone confirm that and give me the correct oil/gas mix ratio? Of course I forgot to ask the seller when I picked up the boat!
    Re: 33 hp Johnson...year and oil mix?
    that is a 1968 as for the mix ratio i would use 50:1 here is a link that will help you decide http://maxrules.com/fixfaq.html#what%20ratio
    • #3
      See also
      http://www.evinrude.com/en-US/About.Us/FAQ/Oil.Fuel.htm
      which confirms 50:1 as the correct mix
      • #4
        I have that exact outboard. Its old and a pig to start but i love the looks and its good on fuel (50-1) good luck!!
        • #5
          Thanks everyone! I'll check out the two sites mentioned.
