We've run the engine on an external tank to take the fuel restriction at the tank/line out of the equation.
Boat runs fine in neutral, can run up and down for whatever periods. As soon as we push in forward and give it the throttle, it drops to a lower idle, than sometimes shuts down. When given a period of rest, it starts up fine and then allows us to give it a small amount of RPM's to limp in on. Mechanic is flabbergasted.
This started out as intermittent issue, but now seems to be consistent.
ANY ideas here would be appreciated.
Thanks
Thanks
