Landscaping Wiz 808
- Jun 29, 2008
- 498
Model #J50ESLEUS
I'm prepping my '97 Johnson 50hp to mount on the back of my MFG once the transom is poured. Today I decided to tango with the tilt assist. It has a little bit of play, but won't allow the motor to be lifted.
I took the bottom mounting bolt out so I could tilt the motor up and gain access to the unit:
I can't get the top mounting pin out! It looks like I should be able to tap it out from the port side (blue arrow) and it should pop out the starboard side (red arrow). Is this right, because I can't get it to budge? I have penetrating oil soaking on it now.
I'm guessing by the damaged parts in the next couple of pictures that I'm going to need a "new" used unit. What do you think?
Dangling line that's connected to nothing:
Here's what 1 end of the line is supposed to connect to, but the threads were torn up by somebody's pliers at some point:
As always, thanks in advance! - Bob
