BryantDennyKennedy
- Jul 8, 2009
- 6
I recently purchased a 71' model Glastron with a 1976 75 hp Johnson outboard engine. When I bought it the guy said it had an ignition problem. I thought it was the solenoid so I replaced it. That wasn't the problem. I can have the switch turned to the off position and the fuse will not blow. As soon as I turn the switch to the on position, the fuse blows immediately. I have a new battery, so the terminals are clean and corrosion free. I have looked for any signs of the wires being faulty as well as corrosion and cannot find anything wrong. I can make me a jumper wire and touch the hot side of the solenoid, (with the key in the off position), to the hot leg of the starter and it will turn over with out blowing the fuse. So I am figuring it has to be before the solenoid. (ex. wiring harness coming from controls or ignition switch) What is a good process of elimination and how do you test these items. I need to find the problem because I am anxious to get it into the water. Someone please advise, it would be greatly appreciated. I am mechanically inclined but I just do not know which way to go. At wits end in Alabama!
