sweetmarie
- Sep 27, 2005
- 115
Every time I tilt my 1986 motor, which is not that often unless I beach it, I end with water in my 2 bottom cylinders and the engine won't start because it being under a hydraulic lock. I have to remove my plugs, turn the engine to flush out the water and then it starts. Any idea of what part of the cooling system (gasket) may be failing for this to happen? Otherwise the motor runs pretty good but for how long unless I find this problem. Thanks anyone.
