The no oil light first happened when I was washing down the engine with hose hooked up. I pump on the primer ball and problem didnt go away. Next day I turned the engine on again and problem diasappeared. Went out the follwing weekend and ran the boat for a least eight hours. and then it happened again no oil light and rpm will not pass 800. When I arrived to my house problem appeared and then went away again. Changed oil filter and primer bulb just in case. Removed one of the oil injection hoses and oil is coming out. Help!!!! Dont want this to happen again. Any suggestions will be appreciated. also noticed oil tank had showed signs of hard vaccum (tank walls collaspes)
