So, I bought a 1975 Browning Aerocraft, it has a 135 horse Evinrude outboard on it. It starts and runs good enough, the only problem is that at cruising speed, it will literally fall on its face like someone shut it off. If i pull back on the throttle quickly, it wont stall, if i dont it stalls, and starts right back up again. It is not a spark issue, because it runs great, no spit or sputter. If i catch it in time and just let it cruise at very low crawl rpm for 30-45 seconds, it will go right back on plane and rev out fine. It feels to me that it is running itself out of gas at high rpms. The tank is 18 gallons, and it seems the lower the fuel level gets the more frequently it does this. Also when it is rough out it seems to do it more also. These may or may not have anything to do with it. Any ideas to fix this problem would be great
P.S. It has new fuel line from the tank to the engine, and a new fuel pump. Thanks Again!
