Well Today I pulled out the old Sea Horse after almost 10 years of sitting. It is my father's and he really doesn't know much about it other than how it used to start and run. I believe it is a 1951 model. The only numbers I could find on it were 926911 and TN 27.
Nosing around the forums I've come up with 1951, but I could be way off base. If I am, some one help me. Anyways, I pulled the plugs, they were dirty, so I cleaned them up because I didn't have new ones. I checked to see if I had spark and there was on each plug. We put some fuel in it (24:1 mixture) and tried priming it with the primer button on the top, but it didn't seem to be working.
I'm assuming I'm going to need to rebuild, clean the carb. I need help with what I'm going to need to order. I want to do it right so I want all of the right parts. Also, there was mention of using a mercury float that has been modified to use, but I haven't found any specifics on how to modify it. Anybody half a link or info on what to do? We're planning on going through the bottom half and replacing the lube, impeller and such things.
I'm cure I'll have plenty more questions while going through this. Oh, and I have the manuals on order.
