jernstberger
- Jun 9, 2009
- 8
Hi Everyone,
My name is Jon and I'm new to this forum as of a few days ago. I've been looking around to find a forum that I thought had knowledgeable members and that would be willing to help. So, thanks.
As stated in the topic, I have the 1950's 10 HP Johnson Seahorse
Can any of you verify or discredit that it was a 1957 model?
A few days ago, while attempting to pull start the motor, I broke the part
It is a small plastic piece to which are attached two metal wires. I can adhere the fractured pieces together and I know where that piece goes. It's clear that the metal knob at the top of the photo
is where that piece should go. The issue is that I have the piece
and have no idea where it goes or how it connects to the wires from the plastic piece. There is also a small c-shaped clip that I don't have pictured.
Could any of you tell me how to reassemble the pull start assembly so I can start this outboard? When I pull the starter cord out, the spring mechanism will recoil the starter rope. But, it's clear that I'm not making any contact with the crankshaft to start the engine.
Any help is completely appreciated. This is my first personally owned outboard and definitely my first antique. I'll probably be here quite a bit.
Jon
Jon
