Hello,
I recently purchased a 1987 Four Winns Fish/Ski with a 1987 Evinrude 88hp SPL, the motor runs fine, but when you first start (cold) I have to remove the engine cover, flip the red switch out on the choke solenoid and then start it. Isn't there a way around this? Seems that you could wire up a switch near the remote that would stop the neccesity for this. I hear some talk about pushing in on the key switch, but my remote control is white with a black handle that says OMC on it and it has the trimbuttons in the handle.. Will my choke come on by simply pushing in on the ignition switch? I would think that OMC did not intend for its users to have to remove the engine cowl EVERY time they went to start the engine from a cold start.
Bryan
Bryan
