I have a 1979 Johnson 85 that will raise with the power tilt but won't go down. The trim/tilt motor is running and the motor will go down slowly if it is helped by pushing down on the motor while operating the tilt switch. The power tilt rods will not retract at all however. I have been told it might be a sticky valve . If this is the case how could it be fixed.
Thanks in advance
Honer
Thanks in advance
Honer
